How to Solve unable to program the Central Control Module (CCM) using Vetronix Tech2
twilaeyql88
Points
Autonumen found a good way to solve unable to program the Central Control Module (CCM) using Vetronix Tech2.
How-to-Solve-unable-to-program-the-Central-Control-Module-CCM-using-Vetronix-Tech2.png
Here is the solution.
Models
. 1994-1996 Chevrolet Corvette
The following diagnosis might be hepul if the vehicle exhibits the symptom(s) described in this PI
Condition/ Concern:
The following process should be used to program a service (replacement) Central Control Module (CCM) on a 1994-1996 Corvette:
It may be found option F0: PROGRAM CCM is not available on Tech I.
Recommendation/Instructions.
Note: The PCM must be programmed prior to programming the CCM if both have been replaced.
Program PCM
Remove class 2 line from DLC pin position number 2.
Install Tech 2 and request information from the vehicle, download PCM calibration from TIS to the GM Tech 2, and then upload it to
the vehicle.
Reinstall class 2 line to the DLC.
Program CCM
Install the Tech 1 with VIM cable adaptor P/N 3000091.
Select programming, model year, 4th digit of the VIN, select the module (CCM), Program CCM, select location (North America), enter the rest of the VIN, select transmission type, odometer select (miles or kilometers), enter odometer reading, programming is complete.
Note: Tech1 adaptor TA02149 will only work on the 12-pin DLC connectors that are typically found in model year 1993 and
prior.
