Scania SDP3 v2.52.3 + XCOM v2.30 +SOPS editor+Scania Multi v2110
manachkin
Scania Diagnos & Programmer3 v2.52.3+XCOM v2.30+SOPS file Encyptor/Decryptor+SOPS XML+Scania Multi v2110 (Remote installation of Teamviewer)
Year/Release Date: 07.2022
Version: 2.52.3
Dealer diagnostic program for Scania Scania Diagnos & Programmer 3 (SDP3) communicates with Scania vehicles and industrial and marine engines Scania. The program is designed to ensure that the electrical system in the CAN network. The program is used for Troubleshooting, setting the parameters preferred by the client, performing calibrations, performing upgrades affecting the electrical system, and updating the software of the control units. To use the program requires a PC, USB dongle and VCI. SCANIA VCI2, VCI3 adapter.
The program supports the following vehicles:
L, P, G, R and S series (2016-)
P, G, R and T series (2003-)
F, K and N series
The program supports the following engines:
P96
E2011
New Feature • Check wizard for fuel level measurement for the sensor from bodybuilder now also applies to trucks.
Correction • Correction of Checking the EGR circuit to verify rectified faults
Scania XCOM is a diagnostic program for reading, saving and changing ECU data, such as error codes, statistical data parameters, etc., using the Scania VCI2 or Scania VCI3 interface, which is used to connect to the ECU via the CAN protocol.
Scania SOPS are files that are used to store information about the parameters of all units and modules of a truck or bus.
The working principle of Scania SOPS file Encryptor/Decryptor Editor
The Scania SOPS software works as a SOPS file encoder-decryptor
Working with Scania SOPS editor is extremely easy even for a beginner:
1. Download the SOPS file of any Scania model to your computer using SDP3.
2. SOPS to convert the file to XML format.
3. Edit an XML file using any XML editor (for example, Excel).
4. Change more than 300 parameters, such as AdBlue, EGR, NOx Control, etc.
5. Convert the XML file to SOPS.
6. Upload the SOPS file to the car using SDP3.
Supported diagnostic interface
SCANIA VCI 2
SCANIA VCI 3
Languages
German, English, Spanish, Chezh, Finnish, French, Italian, Japanese, Korean, Dutch, Polish, Arabic, Portuguese, Russian, Swedish, Turkish, Chinese, Romanian
OS Support Windows 7/10/11 (32/64)
Data release 2022
Cost $99
Write me a message PM
live imacdigger
    2 MB · Просмотры: 11
    260.9 KB · Просмотры: 12
