FAQ Cummins Insite Pro 8.5 - софт для диагностики
Да походу он нас кинул ребята))))
Раз топикстартер оказался гвидоном, то вот альтернатива.
Скачать всё одним архивом
Отдельно
Отдельно
Талмуд на басурманской мове.
1. First unzip 8.5 and run "admininstall" as admin.' Once Install go to Step 2.
2 Use "Cummins Update Manger and upgrade 8.5 to 8.5.2 ( that means do all update First to 8.5.1 then to 8.5.2)
How to activate
This method use a sideloader just like 8.3 so will need run 8.5.2 in Simulation mode.
Put the Sideloader folder on your C: Drive
Next go into the folder and you will see "Cummins Insite 8.5.2" Create a destop shortcut to your desktop
Next go to Keygen folder and navigate to folder "EXE" inside that folder you wiil see WLGEN run it
Next double click on your shortcut desktop icon for the Insite 8.5.2 that you made you it will show HWID don't worry you don't need to write it down it
will auto copy the hwid
Go back to the WLGEN tool and click on License Manager and then click " Add License " Put any Customer name you want next click Hardware ID and right click to paste the
Hardware ID into the spot.
Make sure set a Date of Experiation or else the sideloder will not work
Next click save then to Create License Key Now go look into the folder that is just made and copy the registery.dat file
Place that file into the sideloader Folder on the C drive that has Cummins 8.5.2 sideloader
Now go back to your desktop and launch 8.5.2 shortcut > I will repeat if ask you click on the simulation
For the Folks don't know to use the program
This work's like 8.3 so the zapit and fleet counts are built into the side loader you don't need no key's
Only way the zapit will work or show up is to be connected to the ECM. Once connected to a lock ecm it will show up after a few minutes...
Update on 03/31/2020
For those of you are having problem doing the updates of the folder, the solution is easy.
Run update manger as admin
Then drop the box down to "browse"
Then do the update folder in order
First 8.5.1.82
Then 8.5.2
Спасибо !
С каким адаптером будет работать ?
Что значит "скорее всего"? Работает в полный рост! Даже с китайским.
Китайцы умудрились SM2Pro запилить? Вот это да.........
Уже пол года как продают на Алиэкспресс в открытую!
Я брал -
(алюминиевая коробочка). Имею оригинал и "китайца", разницы в работе не заметил.
Пацаны! А нет ни у кого видосиков, по пользованию программой Cummins insite 8.5.
Отдельно
Отдельно
инструкция по установке
