Есть решение MHHAUTO.COM помогу скачать с сайта!
  • update_version_55569663_FA5B_C_FME6_54_FIEF_81b.rar
    273.2 KB · Просмотры: 5
Я купил готовый аккаунт в магазине
Но все равно вложения вы скачаете но почти на все файлы нужно писать автору в ЛС чтобы получить пароль от архива который вы скачали)
Добрый день . Помогите скачать
System Requirement
Win RAR Must be installed
Work only on Windows 7 32 bit SP1 (recommend Pro, Ultimate, not Home edition)
1. Control Panel-User Account-Change User Account Control settings- set USC slider at minimum. Restart PC.
2. Enter in archive Runtime 5.6.1, Run "SETUP" directly from archive!Is important, otherwise you will get error (Laptop must be powere to install)
a. Close windows with check VCI, pres Yes (Are you sure you want to bypass this step)
b. Close windows with warning message (Configuration manager cannot access vci.....), then pres CANCEL in windows VCI Configuration Manager
Step a. and b. is necesary if installation will made without VCI-560 connected
After finish press, No, I want to restart the computer later
3.Open "daf crack" folder.
copy wkscode and gereatenumer to
C:\DAVIE\hldata
copy userdaf and users to
C:\DAVIE\home\daf
first logon as adminnistrator:
user:admin
pass: admin and next: daf
user:
user: daf
pass: daf
4.Set computer date back to year 2020!
5. Start DAVIE for the first time, Login ADMIN, pass ADMIN, then DAF!
Press ADMINISTRATION then INSTALL UPDATE
Point to folder "PartsRapidoSubset_v19.04.F0" select label and press OPEN, then press OK and wait till update is installed.
After that, press again "Administration" - "Install Update" and point to folder Global After Sales (EN-glish, RU-sian, or RO-manian) depending on which language you want to use software.
6. After installation DAVIE will be restarted, LOGIN again (admin, daf),pres Administration, then Passwords
At 3rd line after ADMIN and DAF user ID, create new User id "TECH" Password "TECH" and pick Senior tech and Master tech!
Logout and close DAVIE
7. Now proceed to activate software with unexpiry fix.
Enter in folder Expire fix, GetHWID
Copy file just created (like this A63DAF48) in folder Keygen
Run Keygen, select file A63xxxx generated previous, new file is generated DavieLic, copy this file in C:\
Run Davie561Fix
Now you can set computer date to actualy date
8.Enter in folder developer tool and Copy "DavieDT+Get_HWID_DavieDT" somewhere in computer, in c:\ is ok
Make shortcut to DavieDT to desktop, and run Get_HWID_DavieDT, copy HWid and open folder DavieDT KG and Run WLGen_DavieDT, press "License Manager", "Add license" at customer write DAF, at Hardware ID paste HWID previously copied, Save, then Press 'Create License Key", close license manager.
Copy DavieDT.dat file (from DavieDT KG/DAF-) to folder with DT.
Open DavieDt, press Service Access, from now, DAVIE login will be:
For working user
User:TECH
Pass:TECH
For Administration
User:ADMIN
Pass:ADMIN
9. Enter in folder Devkit
Copy folder Daf Devkit in C:\
Make shortcut to Devkit2 file, to desktop.
Run GetHWID and HWID file will be generated, copy HWID file to Keygen folder, run DafDev_Keygen, press Load from HWID, point to HWID file, press Make, then Save, new file was generated "DevKit.DKLF" copy this file in C:\Daf Devkit
Thats all!
I can do Remote install for just 50 eur!
PM Me if you are interested!
Реакции: dimon85
    dimon85
    Спасибо большое очень помогли
Приветствую, будьте так добры, скачайте пожалуйста )
Заранее благодарю ?
11.07.2023
Subaru Select Monitor 26.6 for Scanmatik 2 Pro v1.0 Windows XP x86. VMware 11+
Subaru Select Monitor 26.6 for Scanmatik 2 Pro v2.0 Windows 10 x86. VMware 15.5
Subaru Select Monitor 26.6 for Scanmatik 2 Pro v2.0 Windows 10 x64. VMware 15.5
  • SSM3xSM2Pro.rar
    114.8 KB · Просмотры: 18
